ifcOpenShell; How to get the surface of wall openings?
I am trying to use IfcOpenShell for QTO. As the title says I am trying to get the surface of the wall openings.
I used the dir() method a lot and got from a IfcWall instance with "HasOpening" to a IfcRelVoidsElement **and then with "RelatedOpeningElement" to **IfcOpeningElement.
https://standards.buildingsmart.org/IFC/RELEASE/IFC2x3/TC1/HTML/ifcproductextension/lexical/ifcopeningelement.htm
According to the literature the quantites of an IfcOpeningElement are defined by the IfcElementQuantity. But if I try the IsDefinedBy method on a Opening I get nothing.
What am I missing? Is there a simpler way to do this?
An easier way to get properties of an opening (or any element) is:
See if you find quantities in there. If not, then you need to do a bit of geometric analysis.
