BlenderBIM: IfcOpeningElement
Is it possible to "type parameter" an IfcOpeningElement in the BlenderBIM add-on?
What's the reaons IFC does not have support for an IfcOpeningElementType? Or does this work differently in IFC?
I want to be able to type openings in the BlenderBIM add-on. or could this be done in another way with the BlenderBIM add-on?
Do you mean having parametrized settings for opening elements types like, height, depth, width ?
@Gorgious
That's exactly what I mean :-)
It doesn't seem to be possible to have typed Opening entities. A Window Type doesn't even have height and width attributes, so you can't derive the opening from this (blenderbim derives the opening from the X and Z dimensions of the Window bounding box, but this fails when a window has projections). Also openings are not always rectangular anyway.
I don't know what the solution is. I was considering giving the Window Type another Representation in the shape of the opening, this can then be ignored by most software, but optionally used to generate openings on the fly (the openings still wouldn't be typed, so the IFC would still bloat).
Maybe fancy-shaped openings could be Mapped Item, this wouldn't bloat so much.
also curious.
related: https://github.com/IfcOpenShell/IfcOpenShell/issues/1806
This looked like a good idea, but it seems that Opening Elements have to have a Body Context, but a Window Type can only have one Body representation (I think, please correct me), so the opening geometry can't be stored in the Window Type like this.
Just experimenting a bit
How can you resize a mesh in Blender relative to their position?
cross-posted here:
https://blender.stackexchange.com/questions/264629/resize-edit-multiple-meshes-relative-to-their-orientation-position-blender
EDIT:
I know it's possible with Archipack, wonder how archipack does it.
Extrude manifold with indivual origins seem to work, but I wonder if this doable when you have to select all faces of different openings with
different orientations. Is it possible to assign a label/parameter/whatever to a face of a mesh?
Using Alt+D for an IfcOpeningElement seems a very easy way to resize openings depending on orientation, but then you lose roundtripping capabilities. Doesn't always seem to correctly set the opening
