I would like to get started hacking on the new BCF parser.
Assumed I have a bcf and latest IfcOpenShell. Does someone has a code snipped to get a list of viewpoint objects GUIDs by Python?
cheers bernd
from bcf import bcfxml
bcf = bcfxml.load("/path/to/file.bcf")
for topic in bcf.get_topics():
viewpoints = bcf.get_viewpoints(topic.guid)
for viewpoint in viewpoints:
print(viewpoint.guid)
Just tested. Please note that bcf lib only supports version 2.1 and 3.0.
for topic_guid in bcf.get_topics():
viewpoints = bcf.get_viewpoints(topic_guid )
for viewpoint_guid in viewpoints:
print(viewpoint_guid)
I think get_topics should return a list of Topic objects and get_viewpoints should return a list of Viewpoint objects. That sounds more pythonic. What do you think @Moult ?
thanks very much ... I had to adapt it a bit to get it working.
import sys
sys.path.append("C:/Users/BHA/Desktop/bcftest/bcf")
bcf = bcfxml.load("C:/Users/BHA/Desktop/bcftest/Issues_2021-06-24_20.26.bcf")
for topic_guid, topic_obj in bcf.get_topics().items():
print(topic_obj.title)
viewpoints = bcf.get_viewpoints(topic_obj.guid)
for viewpoint_guid, viewpoint_obj in viewpoints.items():
print(viewpoint_obj.guid)
this is what it came out ... :-)
>>> import sys
... print(topic_obj.title)
... viewpoints = bcf.get_viewpoints(topic_obj.guid)
... for viewpoint_guid, viewpoint_obj in viewpoints.items():
... print(viewpoint_obj.guid)
test_2
8eb860dd-735e-45ac-b368-8975382a2da4
test_4
4611f220-647f-4d56-b196-d355c39e44a6
test_1
d77374e9-97a1-4c03-9a42-9254cd432798
test_5
4ab0b1f5-ade5-46ff-a376-be2eb4770ca7
Decke UG inkl Rampe
841b257c-dc37-458a-bc6a-d0dddb2074d4
test_3
82c10923-da08-478a-8a0f-286ca8446108
c978fb25-f881-4ef5-9c15-19edf842a638
a list of the objects would make things easier, thats True
Isn't a dictionary better than a list? In a list you need to sort through all to find the topic you want, whereas a dictionary (like it currently returns) you can find the topic by its ID, or run through its .values() as a list if you wished?
Ahh yes this would have been easier than what I have used.
Mhh most other parser libraries I know use list in such circumstances. For playing around a list is way simpler. Just assign the first item [0] to some variable and play around in python shell.
Eventually it does not matter. As htlcnn said a list just feels more pythonic.
BTW:
great stuff this bcf library, will need and use it to read some information out of bcfs.
It would be awesome to replace the current FreeCAD bcfplugin lib with this one, since this one fixes many of the issues the bcfplugin had, and is updated for the latest BCF specs.
yes for sure it makes sense to use your new parser. JFYI ... ATM this is not near the top of my OSS AEC TODO ... I just do not need it. There is BIMTester which is much more near the TOP and does not get done either ... I still use the version befor your big changes ... but on a daily basis ... :-)
it seams there has been taken place some API change ... following the code which works with latest BBIM for me to get main information out of the bcf ...
bcf = bcfxml.load("C:/Users/BHA/Desktop/test.bbbim_zoom3_extended.bcf")
print("{}: {}".format(topic_guid, topic_obj.topic.title))
for viewpoint_guid, viewpoint_obj in topic_obj.viewpoints.items():
print(" {}".format(viewpoint_obj.guid))
inside BBIM ...
... print("{}: {}".format(topic_guid, topic_obj.topic.title))
... for viewpoint_guid, viewpoint_obj in topic_obj.viewpoints.items():
... print(" {}".format(viewpoint_obj.guid))
2ff81b84-6ce6-4607-8d7c-35a7f7714f96: mein zweiter issue
f47abc58-465a-4a8c-aa25-d44abc94c0d7
124cb5d4-ce47-455e-9938-3fc0a2a68a41
9a36adef-b285-4673-a373-c7c03601b5a9
c9c71e3e-b5ac-4a3b-9da6-480a914b5873
81321a8d-8909-45f0-9982-edd0d116a533: myissue
b5ccadb4-af11-4c1b-84df-da9c1a747075
comp = viewpoint_obj.visualization_info.components
# print(comp)
if comp is not None:
print(" view_setup_hints")
print(" {}".format(comp.view_setup_hints))
print(" visibility")
if comp.visibility is None:
print(" {}".format(comp.visibility))
else:
print(" {}".format(comp.visibility.default_visibility))
if hasattr(comp.visibility.exceptions, "component"):
print(" len exceptions {}".format(len(comp.visibility.exceptions.component)))
print(" first exceptions {}".format(comp.visibility.exceptions.component[0]))
print(" selection")
if comp.selection is None:
print(" {}".format(comp.selection))
else:
print(" {}".format(comp.selection.component))
print(" coloring")
if comp.coloring is None:
print(" {}".format(comp.coloring))
else:
# print(" {}".format(comp.coloring.color))
print(" len coloring: {}".format(len(comp.coloring.color)))
print(" first coloring: {}".format(comp.coloring.color[0].component))
print(" color coloring: {}".format(comp.coloring.color[0].color))
else:
print(" {}".format(comp))
print("\n\n\n")
I think it's here: https://github.com/IfcOpenShell/IfcOpenShell/blob/v0.6.0/src/bcf/bcf/v3/bcfxml.py#L657
You could find example to read bcf file here: https://github.com/IfcOpenShell/IfcOpenShell/tree/v0.6.0/src/bcf
Some untested lines:
I think
get_topicsshould return a list ofTopicobjects andget_viewpointsshould return a list ofViewpointobjects. That sounds more pythonic. What do you think @Moult ?thanks very much ... I had to adapt it a bit to get it working.
Glad to see it works :)
BTW:
are there some code examples around to create a new bcf from scratch with the ifcopenshell bcf paraser?
bernd
Try this:
inside BBIM ...
some more viewpoint information ...
even a few more view point information ...
