Error ASC input BlenderGIS
The message is not very clear what the real problem is in row s
Any idea? Thanks!
Small files XYZ attached
Tried , as seperator
No luck
Any idea? Thanks!
No luck
The "maaiveld 5m - kopie.txt" file is not a standard asc file:
https://desktop.arcgis.com/en/arcmap/10.3/manage-data/raster-and-images/esri-ascii-raster-format.htm
I think the script is saying it didn't find a nrow value, which is always in the begining of the esri asc file.
(also a standard asc file contains, apart from the header, only the z values, not x and y as your file)
Thanks. This might be something Cloudcompare maybe can answer and fix.
