IFCPatch tool now available
2»
  • edited January 2024
    I tried to install via pip install ifcpatch but I couldn't.
    How do I download the ifcpatch folder?
    I'm just trying to shift the ifc model on the z axis. I tried using pure ifcopenshell but in each iteration the starting position of the next element is the ending position of the previous iteration. I tried to reset the initial position of the elements but it didn't work.
    import ifcopenshell
    def deslocar_elements(model_ifc, displacement_z):
    for element in model_ifc.by_type('IfcProduct'):
        initial_position = list(element.ObjectPlacement.RelativePlacement.Location.Coordinates)
        new_position = [initial_position[0], initial_position[1], initial_position[2] + displacement_z]
        element.ObjectPlacement.RelativePlacement.Location.Coordinates = new_position
        new_position = [initial_position[0], initial_position[1], initial_position[2] - displacement_z]
    file_ifc = "D:....\model.ifc"
    displacement_z = 20.0
    model_ifc = ifcopenshell.open(file_ifc)
    model_ifc.write("D:...\model_new.ifc")
  • You can download the ifcopenshell repo from Github:
    https://github.com/IfcOpenShell/IfcOpenShell
    I guess you need to clone the repo or download a zip-archive (green "code" button).
    Ifcpatch is located in the src subfolder.
    https://github.com/IfcOpenShell/IfcOpenShell/tree/v0.7.0/src/ifcpatch
    theoryshaw
  • @mcnill thanks! now it worked!
  • edited March 2024
    I am a noob in ifcopenshell and ifcpatch.
    My goal is to create individual ifc files for every prefabricated concrete element with accessories from an existing ifc file created with Tekla. The following code causes an error which i did not find on other forums. Any help or tips are appreciated.
    There are multiple IfcWall entities in my ifc file.
    Perhaps a little context... I work from Belgium, where we use a decimal comma in stead of a point. Maybe this could be important.
    output = ifcpatch.execute({
        "input": "S:file.ifc",
        "file": ifcopenshell.open("S:/file.ifc"),
        "recipe": "ExtractElements",
        "arguments": [".IfcWall"]
      File "S:\IFC\IfcOpenShell\Test ifcpatch ExtractElements.py", line 43, in <module>
      File "S:/Python/Lib/site-packages/ifcopenshell/ifcpatch\ifcpatch\__init__.py", line 79, in execute
        patcher.patch()
      File "S:/Python/Lib/site-packages/ifcopenshell/ifcpatch\ifcpatch\recipes\ExtractElements.py", line 64, in patch
        for element in ifcopenshell.util.selector.filter_elements(self.file, self.query):
      File "S:\Python\lib\site-packages\ifcopenshell\util\selector.py", line 263, in filter_elements
        transformer.transform(filter_elements_grammar.parse(query))
      File "S:\Python\lib\site-packages\lark\lark.py", line 658, in parse
        return self.parser.parse(text, start=start, on_error=on_error)
      File "S:\Python\lib\site-packages\lark\parser_frontends.py", line 104, in parse
        return self.parser.parse(stream, chosen_start, **kw)
      File "S:\Python\lib\site-packages\lark\parsers\earley.py", line 279, in parse
        to_scan = self._parse(lexer, columns, to_scan, start_symbol)
      File "S:\Python\lib\site-packages\lark\parsers\xearley.py", line 152, in _parse
        to_scan = scan(i, to_scan)
      File "S:\Python\lib\site-packages\lark\parsers\xearley.py", line 125, in scan
        raise UnexpectedCharacters(stream, i, text_line, text_column, {item.expect.name for item in to_scan},
    lark.exceptions.UnexpectedCharacters: No terminal matches ',' in the current parser context, at line 1 col 1
    ,IfcWall
    Expected one of:
        * ESCAPED_STRING
        * BANG
        * __ANON_3
        * TYPE
        * __ANON_1
        * __ANON_0
        * SLASH
        * __ANON_4
        * LOCATION
        * CLASSIFICATION
        * __ANON_2
        * MATERIAL
  • @glennvnbc try with ["IfcWall"] without the dot
  • edited March 2024
    @Massimo thanks for the respons
    when using ["IfcWall"] i get
      File "S:\IFC\IfcOpenShell\Test ifcpatch ExtractElements.py", line 44, in <module>
      File "S:\Python/Lib/site-packages/ifcopenshell/ifcpatch\ifcpatch\__init__.py", line 79, in execute
        patcher.patch()
      File "S:\Python/Lib/site-packages/ifcopenshell/ifcpatch\ifcpatch\recipes\ExtractElements.py", line 65, in patch
        self.add_element(element)
      File "S:\Python/Lib/site-packages/ifcopenshell/ifcpatch\ifcpatch\recipes\ExtractElements.py", line 70, in add_element
        new_element = self.append_asset(element)
      File "S:\Python/Lib/site-packages/ifcopenshell/ifcpatch\ifcpatch\recipes\ExtractElements.py", line 87, in append_asset
        return ifcopenshell.api.run(
      File "S:\Python\lib\site-packages\ifcopenshell\api\__init__.py", line 66, in run
        result = usecase_class(ifc_file, **settings).execute()
    TypeError: Usecase.__init__() got an unexpected keyword argument 'reuse_identities'
    I am using IfcOpenShell (0.7.0.231218) - latest version to date
    The documentation on blenderbim has the following information for class ifcopenshell.api.project.append_asset
    class ifcopenshell.api.project.append_asset.Usecase(file, library=None, element=None,reuse_identities=None)
    The current ifcopenshell\api\project\append_asset.py does not have a parameter "reuse_identities"
    def __init__(self, file, library=None, element=None):
    Ifcpatch ExtractElements calls api.project.append_asset with reuse_identities
    return ifcopenshell.api.run("project.append_asset", self.new, library=self.file, element=element, reuse_identities=self.reuse_identities)
    Is this a recent update issue?
    yes, you'll need to update ifcopenshell
