autosectionlabel - Blenderbim v0.0.240303 - Blender 4.0 - Win10
I need some Help! I am trying to do some basic documentation plans, but autosectionlabel is not working. I don't see any annotation marker level.
Any suggestion? Thaks!
Can you share the .ifc file, that you started?
Hi! There are some aditional errors but I don't understand what is the reason.
If you're a new user, it's recommended to not even save the .blend file, as there are often syncing problems. Just save the .ifc file.
I think there were syncing problems with your current .blend/.ifc, as there's no drawings if you open just the .ifc file.
Unfortunately, i don't think there's a way to resurrect your drawings from the .blend file.
I would just start with your current .ifc file, and go from there.
Hi! Couldn't reproduce the issue. Can you please reload .ifc file and try to describe steps (or record a short demo) how to replicate the error?
