Connecting Spaces of a Stair
edited March 2024 in General
I was trying to find connected spaces using IfcOpenShell. But I couldn't find a way to extract the spaces connected by a stair. I am using the FZK Haus as the sample file. I have tried the geometry tree approach and was able to find the bottom space connected but not the top space.
    Hi! Can you please show the code that didn't worked?
    Just tested the code below with bounding box selection:
    import ifcopenshell
    ifc_file = ifcopenshell.open(r"AC20-FZK-Haus.ifc")
    import multiprocessing
    import ifcopenshell.geom
    from pprint import pprint
    def check_intersections(ifc_file):
        tree = ifcopenshell.geom.tree()
        iterator = ifcopenshell.geom.iterator(
            settings, ifc_file, multiprocessing.cpu_count()
        if iterator.initialize():
            while True:
                tree.add_element(iterator.get_native())
                if not iterator.next():
                    break
        element = ifc_file.by_type("IfcStair")[0]
        pprint(tree.select_box(element))
    [#59290=IfcSlab('2RGlQk4xH47RHK93zcTzUL',#12,'Slab-033',$,$,#59253,#59286,'DA0A17AC-B773-47AC-99-C5-D390C73AD5CC',.FLOOR.),
     #33774=IfcSpace('0Lt8gR_E9ESeGH5uY_g9e9',#12,'5',$,$,#33683,#33769,'Wohnen',.ELEMENT.,$,$),
     #59365=IfcOpeningElement('16PF6khT5_p$Z03P73inyv',#12,'Slab Opening',$,$,#59331,#59361,$,$),
     #39432=IfcMember('1qMEiq1Qz6guq8g1GCODiJ',#12,'Sparren-34',$,$,#39415,#39428,'3A999AF6-1C12-413A-89-B2-BF4A3CAEAD63',$),
     #39186=IfcMember('1NBDw_i_jD$u7IjvwmbPmx',#12,'Sparren-32',$,$,#39169,#39182,'62D6313A-B4FB-45BF-B3-97-10D01124A4F9',$),
     #39309=IfcMember('2DH$OLoObDkAtwqVzNdUnS',#12,'Sparren-33',$,$,#39292,#39305,'E4FF91FA-3AE7-4591-8D-5F-61E57F7BA5DE',$),
     #14502=IfcStair('38a9vdh9bF5Qg28GWyHhlr',#12,'Wendeltreppe',$,$,#502,#14498,'79A67A01-C95B-4209-86-9A-74983B65305C',$),
     #59753=IfcSlab('2IxUUNUVPB6Ob$eicCfP2N',#12,'Dach-2',$,$,#59716,#59749,'BD6D9414-37DF-40A8-88-40-301A32A9A5B5',.ROOF.),
     #49831=IfcRailing('0o5vgCKyTBzO5$QJcI2YDP',#12,'',$,$,#40768,#49827,'00000000-0000-0000-00-00-000000000000',.HANDRAIL.),
     #76214=IfcSpace('2dQFggKBb1fOc1CqZDIDlx',#12,'7',$,$,#76123,#76209,'Galerie',.ELEMENT.,$,$)]
  • @Andrej730 Thanks. This code is working. I think the part that is not working in my code is where i specified IfcSpace as include items.
                settings, ifc_file, multiprocessing.cpu_count(),  include=("IfcSpace")
    But if i remove the include parameter, it is working. Thanks again.
