BBIM not loading certain elements
Hi there!!
I've been experimenting some issues when importing an IFC from Tekla Structures.
BBIM doesn't seem to import all the elements in the IFC.
I include two screenshots of the same model, loaded into BBIM and BIM Collab Zoom.
Any clues on what's happening and how can I fix it?
Thanks in advance!!!
I think the ifc schema gurus need to access the contents of the ifc file to see why the elements don't load. Are you allowed to share it, or maybe share a stripped down version with only some elements that don't load ?
@leGordeau
What BBIM version you're using?
To fix those kind of errors we indeed will need some .ifc example to reproduce the issue.
Thank you both for your replies.
I'm figuring out how to extract a portion of the IFC file to share with you.
As soon as I manage to do that, I'll post it here.
Thank you!!
Buenas,
Even before sharing the file, you may identify where the problem lies by validating it with IfcOpenShell, which can be done from inside BlenderBIM as follows:
You'll need to have started Blender from a console, in which the validation results will be printed.
Thanks for the advice, @cvillagrasa
I'll do that test to see if that gives any clues.
Saludos!
