IfcMerge - 'Merge this Branch' doesn't seem to work
@brunopostle Hi again. :)
It doesn't seem like 'Merge this Branch' should be grayed out--perhaps I'm missing something.
created a simple repo, to test... https://hub.openingdesign.com/OpeningDesign/GIT_test.git
bb 20240605
I switched that to
true
to just test...Then tried to merge branch.
Got this error
BlenderBIM doesn't ship with ifcmerge.exe, you have to download it and put it in your PATH.
It could be added to the BlenderBIM installer, or at least a setting like the file association. Unfortunately, the way that git handles merges it has to be a separate executable file.
Ah, I think that was the problem, i thought it was installed with BB. Thanks!.. will try and install.
Got it to work!..Thx.
Added some install instructions, if you think useful: https://github.com/brunopostle/ifcmerge/pull/12/files
