ifcopenshell scripting on IFC file loaded in BlenderBIM
I just started exploring BlenderBIM and I was looking if I could directly access the IFC project loaded in Blender through BlenderBIM, to be able to combine the UI from BlenderBIM and scripting whenever needed.
In particular, I want to assign ifc class to 3d objects already loaded in blender through scripting instead of UI. The UI looks like this:
Sure, pull up a Python console or text editor, then you can get the active session's model by doing:
When you say model, you mean the IFC project that i created ? This one for instance :
Also, now that I got the model (or project), let's say that I have a terrain mesh in my .blend project to which I want to assign the class "IfcGeographicElement" and put it into my ifc project, how do I proceed? I saw that the blenderbim.tool module contains a lot of useful classes and methods, but I'm at loss at how to use them.
asaik IFCProject is a space class instance, not the IFC model
when you read ifcopenshell 'model' is the one you use in the APIs
etc..
the same 'model' (at times 'file' in the example), is the one used in most of the API
sorry I am not too much of an expert, I only use the cost APIs from time to time, hope it helps
yes, I understand!
I found a very interesting comment of @Moult in this thread https://community.osarch.org/discussion/2201/documentation-on-blenderbim-python-library#latest and I'm trying to work accordingly. I used blenderbim.tool to get the model then ifcopenshell calls for model processing. However I'm finding it hard to pinpoint the methods and classes I need. Is there a solid documentation of the ifcopenshell python API ?
https://docs.ifcopenshell.org/ifcopenshell-python.html includes code examples and a short tutorial. https://docs.ifcopenshell.org/autoapi/ifcopenshell/index.html contains extensive documentation. Also see the API and util submodule.
