Colour in different IFC viewers?
I've opened the same IFC in:
  • Solibri
  • OpenIfcViewer
  • BlenderBIM
The colour of the beam is different in each. Is there some way i can fix this?
Attached my IFC file
  • Are you sure that's the same file? It looks grey to me.
  • @Moult you are correct. I've tried to replicate my problem in a simple way. Let me try again:
    I'm creating a IfcBeamType with the following code:
    When I'm opening it with BlenderBIM 0.0.240602 the colour is correct.
    When I'm opening it with Bonsai 0.0.240815 the colour is grey.
    With other Viewers it's as above.
    What am I doing wrong?
    import os import ifcopenshell import ifcopenshell.api def main(model): material = model.by_type('IfcMaterial')[0] profile = model.create_entity( "IfcIShapeProfileDef", ProfileName="I-EXAMPLE", ProfileType="AREA", OverallWidth=0.100, OverallDepth=0.200, WebThickness=0.010, FlangeThickness=0.015, FilletRadius=0.010 ) profile_set = ifcopenshell.api.run( "material.add_material_set", model, name="profile_name", set_type="IfcMaterialProfileSet" ) ifcopenshell.api.run( "material.add_profile", model, profile_set=profile_set, material=material, profile=profile ) beam_type = ifcopenshell.api.run( "root.create_entity", model, ifc_class="IfcBeamType", name="beam_type_name" ) ifcopenshell.api.run( "material.assign_material", model, products=[beam_type], material=profile_set ) return model if __name__ == '__main__': ifc_name = 'test2.ifc' ifc_file_path = os.path.expanduser(f'~/Desktop/{ifc_name}') model = ifcopenshell.open(ifc_file_path) model = main(model) ifc_name = 'test3.ifc' ifc_file_path = os.path.expanduser(f'~/Desktop/{ifc_name}') model.write(ifc_file_path)
  • Your code doesn't do anything related to colours, so not sure what to say about your code.
    However test3.ifc correctly has a blue colour. In the version released on the Blender extensions store, it may show up as grey, and that's just a temporary regression while we switch to v0.8. It's already been fixed but we haven't yet released a version with the fix I think. Blue is the correct colour, the other two IFC viewers have a bug.
  • Ok, thank you, @Moult
    So that bug in the other software seems to only exist for Beams/Columns (Extrusions?)
    So if I Tessellated the Beam, it should show correctly? Unfortunately I don't manage to
    import ifcpatch, ifcopenshell
    import os
    ifc_name_in = 'test3.ifc'
    ifc_file_path_in = os.path.expanduser(f'~/Desktop/{ifc_name_in}')
    ifc_name_out = 'Tessellated.ifc'
    ifc_file_path_out = os.path.expanduser(f'~/Desktop/{ifc_name_out}')
    output = ifcpatch.execute({
        "input": ifc_file_path_in,
        "file": ifcopenshell.open(ifc_file_path_in),
        # "recipe": "Optimise",
        "recipe": "TessellateElements",
        "arguments": ['IfcBeam'],
    ifcpatch.write(output, ifc_file_path_out)
    gives the following error:
    Note: API not available due to missing dependencies: geometry.add_representation - No module named 'bpy'
    Note: API not available due to missing dependencies: grid.create_axis_curve - No module named 'bpy'
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/entity_instance.py", line 352, in __setitem__
        self.method_list[idx](self.wrapped_data, idx, entity_instance.unwrap_value(value))
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/ifcopenshell_wrapper.py", line 6570, in setArgumentAsAggregateOfInt
        return _ifcopenshell_wrapper.entity_instance_setArgumentAsAggregateOfInt(self, i, v)
    TypeError: Attribute of type AGGREGATE OF INTEGER needs a python sequence of ints
    During handling of the above exception, another exception occurred:
      File "/Users/smr/Desktop/test2.py", line 15, in <module>
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcpatch/__init__.py", line 84, in execute
        patcher.patch()
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcpatch/recipes/TessellateElements.py", line 115, in patch
        mesh = ifcopenshell.api.run(
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/__init__.py", line 92, in run
        return usecase_function(ifc_file, should_run_listeners=should_run_listeners, **settings)
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/__init__.py", line 258, in wrapper
        raise e
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/__init__.py", line 252, in wrapper
        result = usecase(*args, **settings)
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/geometry/add_mesh_representation.py", line 59, in add_mesh_representation
        return usecase.execute()
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/geometry/add_mesh_representation.py", line 66, in execute
        return self.create_mesh_representation()
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/geometry/add_mesh_representation.py", line 71, in create_mesh_representation
        return self.create_polygonal_face_set()
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/geometry/add_mesh_representation.py", line 96, in create_polygonal_face_set
        faces = [self.file.createIfcIndexedPolygonalFace([v + 1 for v in f]) for f in self.settings["faces"][i]]
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/api/geometry/add_mesh_representation.py", line 96, in <listcomp>
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/file.py", line 379, in create_entity
        e[idx] = arg
      File "/Users/smr/opt/anaconda3/envs/structural/lib/python3.10/site-packages/ifcopenshell/entity_instance.py", line 354, in __setitem__
        raise TypeError(
    TypeError: attribute 'CoordIndex' for entity 'IFC4.IfcIndexedPolygonalFace' is expecting value of type 'AGGREGATE OF INT', got 'list'.
