Help with linked IFC's
Good morning to all!
I am working with numerous downloaded ifc's from a large project I am working on, and wondering if there was a way to load them all at once, into their own collections (a little like what linking an ifc does), so that I can copy the actual geometry out.
I need to have a single .blend file with all the geometry in it so that I can do a single lage intersection and cut operation with my DTM mesh. This I usually do in Cyclone 3DR, as Blender's Boolean gives me quite mixed result when cutting a non solid mesh with volume elements.
I have tried linking the ifc's and copying them out, though that doesn't work, and loading each ifc (over 50) manually and copying out is quite time consuming.
Is there anyone who has a similar situation and might be able to provide me with some assistence?
Thank you all in advance, and I hope you're having a super dooper day!
Ryan
steverugikmnoffMassimo
