use property value for quantity schedule
i have an ifc file with a custom pset for geometries / quantities. unfortunately it is not a quantityset.
i am wondering if there is a way in the cost module to calculate with such a property value instead of a quantity.
thank you
  • edited November 2024
    hi @PeterKop
    a bit more info would be helpful but in general you can use custom quantities in your Cost Schedule and Spreadsheet
    say you have a custom Qto "MyDimension" with 4.5 value assigned to a wall
    you can call it from the drop-down list in the Cost Schedule
    hope it heps, cheers
  • steve you are right, there is more info needed.
    what i have is structured objects - mostly IfcBuildingElementProxies with different types, which act as classification.
    these objects have a given pset/property structure.
    one pset ist for geometry:
    i created a structured cost item table:
    as you see i collected the items by class.
    what i want to achieve is to use the "Volumen" property in my structure as quantity in my cost items.
    for me the manual creation of quantities to be assigned instead of a value already assigned does not feel right.
    thank you peter
    @PeterKop
    If Volumen is a custom qto (inside Quantity Sets) you can use the example I posted above , manual calculation is only needed when such info is not available
    does it make sense? please advise
    EDIT
    if your quantities are a custom Pset instead, they do not show in the drop-down menu, in such case I don't know how to move info from Pset to Qto using the user interface, maybe with Python? hopefully someone else will come to the rescue here :)
  • my quantity is not part of a quantity set.
    in my understanding following your advice i had to manually assign values to a new quantity "Volume" in a quantityset "MyQto"
    the question is, if there is a way to take the property volume - not being a member of a quantity set - and use it in the cost schedule
    steverugi
    can you try this?
  • Steve thanks for the hint, i will test tomorrow morning and report back
    steverugi
  • stefano, there seems to be something wrong....
    here my input
    here the error message
    will have to examine the ifc data.
  • I was looking at your images in the previous post, lots of proxy elements there, as far as I understand you need to use a unit compatible with the assigned class, see below from ifcpatch.recipes
  • stefano, changed the target to NetVolume -> should be available in all qto_sets including Qto_BuildingElementProxyQuantities (according to bs documentation)
    analysing the persisting error:
    the object (IfcBuildingElementProxy) exists, the relations to the property name exists ("Volumen") in a pset("...Geometrie")
    the assignment of NetVolume is valid.
    seems debugging is necessary
  • Hi @PeterKop
    please would you post an issue on this link
    I did quickly try it yesterday and couldn't get it right either, thanks
    stefano, i found first typos in the code:
    the original code:
    if value and not has_quantity:
    qto_name = self.get_qto_name(product.is_a())
    qto = qtos.get(qto_name, ifcopenshell.api.run("pset.add_qto", self.file, product=product, Name=qto_name))
    "pset.edit_qto", self.file, qto=qto, Properties={self.destination_quantity_name: value}
    the updated one:
    qto = qtos.get(qto_name, ifcopenshell.api.run("pset.add_qto", self.file, product=product, name=qto_name))
    "pset.edit_qto", self.file, qto=qto, properties={self.destination_quantity_name: value}
    but still not working, there is more code to edit...
    steverugi
  • @steverugi , i had to add a try / except exception handling to above modifications in the code as i had no quantityset in the model. now he calculation runs very smooth and results are as expected.
    thank you for pointing me in the right direction!
    here my code snippet:
    elif definition.is_a("IfcElementQuantity"):
    try:
    qtos[definition.Name] = definition
    for quantity in definition.Quantities:
    if quantity.is_a("IfcPhysicalSimpleQuantity") and quantity.Name == self.destination_quantity_name:
    has_quantity = True
    except Exception as e:
    self.logger.info(f"Failed to process IfcElementQuantity for product {product.GlobalId}: {e}")
  • Hi @PeterKop
    try:
    has_quantity = True
    Did you try using the patch from the panel in Bonsai?
  • hi @steverugi
    yes, i used the patch from panel in bonsai with above adoption in code
    steverugi
  • @PeterKop said:
    hi @steverugi
    I meant did you use the patch from the panel entering name of property and quantity?
  • @steverugi
    yes, like this:
    after applying my corrections in the code, it worked. data is automatically input in costing module
    steverugi
