DXF Import broken in Blender 4.3
Even though this might rather be a topic for a general blender forum, I thought that most you have some dealings with DXF imports into blender. I usually use it to get land surveys into blender and now with the new blender version it does not seem to work anymore. Something about faces already existing. I found this in blender 4.2.1 as well but first stumbled upon it in its latest version.
Hello, what type of geometry do you have in your dxf file ? Have you tried exploding meshes into 3DFACEs ?
The file in question came from cadmapper.com. Will I be needing extra CAD software to explode meshes into 3dfaces or is that an option inside the importer?
I currently have no access to my normal linux machine thus the windows screenshot of the error message.
I think DXF is generally broken in all Blender Versions (?)
It works fine for me here for simple 2D floor/section/elevation imports by a about 1992 DXF format.
But in import settings, if I try to switch "Import : by Layer" dropdown to top bottom "by Layer and DXF Type and Blocks" - it will immediately crash whole Blender.
