Deleting many objects takes forever
So I have an Architectural model with around 20k elements and I want to delete everything but the concrete shell. Selecting 1000 objects and doing the ifcdelete command takes forever to compute (like 10mins+). Is there a fast way to do this?
Thanks!
  • @ShellNotClosed
    you can try to use a patch (instead of IfcWall use the class you need to export/keep)
    please advise
    theoryshawJanF
  • edited December 2024
    Unfortunately, deleting stuff enmass is slow.
    Considering you only need one thing, could you link the file, and bring in the geometry?
    steverugi
    @steverugi said:
    @ShellNotClosed
    please advise
    Worked! Thank you!
    steverugi
