Is it possible to assign 2 different styles (frame, glass) to a parametric window? I tried this way but after editing Window parameters the styles are lost.
I think that the geometry is regenerated if you change the parametric parameters, so any styles you have applied to representation parts are lost
you can put +1001 on the following :) https://github.com/IfcOpenShell/IfcOpenShell/issues/2981
Allright +1001. C'mon guys, who gives more +1002 ;-)
