IfcTask & IfcTaskTime - ifcopenshell
i'm trying through code to be able to iterate through all IfcProducts, and to list and IfcTask and IfcTaskTime properties.
for example i need to extract IfcTaskTime dates.
type: IfcTaskTime
DataOrigin: USERDEFINED
UserDefinedDataOrigin: None
DurationType: None
ScheduleDuration: None
ScheduleStart: 2025-12-01T08:00:00
ScheduleFinish: 2025-12-03T16:00:00
EarlyStart: None
EarlyFinish: None
LateStart: None
LateFinish: None
FreeFloat: None
TotalFloat: None
IsCritical: None
StatusTime: None
ActualDuration: None
ActualStart: None
ActualFinish: None
RemainingTime: None
Completion: None
i can find this information, but i cant seem to link it back to the IfcTask, which is linked with IfcProduct in this example.
IfcPile is in a relationship with IfcTask using IfcRealAssignedToProduct,
IfcTaskTime is in a relationship with IfcTask using IfcTealAssignedToProcess.
i can see this in the the .Ifc read in notepad. i just cant seem to figure out how to read IfcTaskTime, and see what IfcTask is associated an in turn also know which IfcProduct is assigned.
my latest attempt look like this, greatful for any support or ideas, where i might be going wrong
import ifcopenshell
Load the IFC file
ifc_file_path = r"location to ifc file"
ifc_file = ifcopenshell.open(ifc_file_path)
for rel in ifc_file.by_type("IfcRelAssignsToProcess"):
print(f"RelatingProcess: {rel.RelatingProcess}")
print(f"RelatedObjects: {rel.RelatedObjects}")
Debug: Print all IfcRelAssignsToProcess objects and their details
print("\n--- Debug: IfcRelAssignsToProcess Relationships ---")
for related_obj in rel.RelatedObjects:
print(f" RelatedObject: {related_obj}")
if related_obj.is_a("IfcTaskTime"):
print(f" Is a TaskTime: {related_obj}")
print(f" TaskTime ScheduleStart: {getattr(related_obj, 'ScheduleStart', 'No ScheduleStart')}")
print(f" TaskTime ScheduleFinish: {getattr(related_obj, 'ScheduleFinish', 'No ScheduleFinish')}")
print(f" TaskTime ScheduleDuration: {getattr(related_obj, 'ScheduleDuration', 'No ScheduleDuration')}")
Extract tasks related to IfcPile
tasks_related_to_piles = []
for rel in ifc_file.by_type("IfcRelAssignsToProduct"):
if rel.RelatingProduct.is_a("IfcPile"): # Check if relating object is IfcPile
tasks_related_to_piles.extend(rel.RelatedObjects)
Debug: List the tasks related to IfcPile
print("\n--- Debug: Tasks Related to IfcPile ---")
for task in tasks_related_to_piles:
print(f"Related Task: {task}")
Extract TaskTime relationships
results = []
task_name = getattr(task, "Name", "Unnamed Task")
task_time_details = "No TaskTime Assigned"
print(f"Checking Task: {task_name} for TaskTime...")
print(f" Checking RelatingProcess: {rel.RelatingProcess}")
if rel.RelatingProcess == task: # Match task with process
print(f" Found related task: {task.Name}")
print(f" Checking related object: {related_obj}")
if related_obj.is_a("IfcTaskTime"): # Check for IfcTaskTime
task_time_details = f"Start: {getattr(related_obj, 'ScheduleStart', 'No Start Time')}, Finish: {getattr(related_obj, 'ScheduleFinish', 'No Finish Time')}, Duration: {getattr(related_obj, 'ScheduleDuration', 'No Duration')}"
print(f" Found TaskTime: {task_time_details}")
results.append((task_name, task_time_details))
Output results
print("\n--- Results: Task and TaskTime Details ---")
for task_name, task_time_details in results:
print(f"Task: {task_name}, TaskTime: {task_time_details}")
There are utility functions to do that here: https://docs.ifcopenshell.org/autoapi/ifcopenshell/util/sequence/index.html - any help in writing docstrings will be really appreciated :)
