IfcOpenShell - building a tree and select by ray
I followed the idea in the docs about building a geometry tree and selecting by ray.
However for some reason the following code doesn't work:
import multiprocessing
import ifcopenshell
import ifcopenshell.geom
import logging
logging.getLogger().setLevel(logging.DEBUG)
ifc_file = ifcopenshell.open(r'tests\models\cube.ifc')
tree = ifcopenshell.geom.tree()
settings.logger = logging.getLogger()
i = 0
origin = (0., 0., 0.)
direction = (1., 0., 0.)
length = 50.
if iterator.initialize():
while True:
# Use triangulation to build a BVH tree
tree.add_element(iterator.get())
i += 1
if not iterator.next():
break
logging.debug(f"{i} elements added to tree.")
results = tree.select_ray(origin, direction, length)
print(f"Number of results: {len(results)}")
for result in results:
print(ifc_file.by_id(result.instance.id()))
There aren't any errors, my results is just empty.
However, when I don't use the iterator, like this:
import ifcopenshell
import logging
i = 0
length = 50.
mytree = ifcopenshell.geom.tree(ifc_file, settings)
results = mytree.select_ray(origin, direction, length)
Then I get the results I expect. So I'm pretty sure I'm using the iterator wrong.
Any advice much appreciated, thanks.
Note to my future self, using tree.add_element(iterator.get_native()) works.
