Change Measurement System in Bonsai BIM Template (Imperial → Metric)
Beginner question:
How can I change the measurement system in a Bonsai BIM template? It is currently using the Imperial System, but I need to switch to the metric system.
@BVArq
did you try this patch?
Thanks for your help!
It really works with the template.
I tested it on @theoryshaw's file, but it gave me this error message "TypeError: unsupported operand type(s) for *=: 'entity_instance' and 'float'"
By the way, @theoryshaw, thanks for sharing it with us.
@BVArq can you help report a bug and attach the file that it failed on?
@Moult For sure! Thank you
