From my understanding profiles, materials and styles do not support global identifiers (GUID) like rooted elements do. GUID are used to identify elements uniquely throughout the life of a project, or when you merge different projects to avoid conflicts. So one of the ways to avoid duplicating these without a global identifier is to assume that if they share the same name, they are the same asset. But it's not always true, two projects can independently define a glass material with different properties but the same name, so you can choose if you want to keep both or merge them.
It seams the assume_asset_uniqueness_by_name is activated with the code above.
On some models I get corupted geometry if it is activated. If I run ifcpatch from Blender Gui and deactivate the pref I get no corrupted geometry. If I activate it, I get corupted geometry or even a run break.
I would like to help to debugg the problem ... How can I deactivate the setting in the python code above?
this help?
https://github.com/IfcOpenShell/IfcOpenShell/blob/52af302bef0b967fa7605bfbe59b903ee81eb919/src/ifcpatch/ifcpatch/recipes/ExtractElements.py#L43-L50
thank you guys for the link to the code and for the great explanation ...
from python I use this to run ifcpatch ...
It seams the
is activated with the code above.On some models I get corupted geometry if it is activated. If I run ifcpatch from Blender Gui and deactivate the pref I get no corrupted geometry. If I activate it, I get corupted geometry or even a run break.
cheers
It helped a lot today ... Add
False
to the arguments andassume_asset_uniqueness_by_name
is deactivated :-)
