Hi, i'm facing another struggle with a none closed shape. This time from Rhino i believe. Tried some thing but that did not work well. IFC import have me this. I need someone to show me around to close it and export it to IFC4.
I am new to this but I think you might want to try the 3D print plugin (included in blender just activate it). The cleanup tools seem to get your object to be a solid.
That is just amazing ! Thank you so much for sharing that!!
The tool is in the sidebar and can be shown in Blender with keyboard [N]
It will also give you the volume of your mesh. That is how I discovered it when trying to figure out how to do cut/fill calcs.
Just a hint to ensure that your meshes should be manifold before trusting the volume value :) I've been bitten by that one accidentally!
We will also check the dimensions of the solid after export import. But it looks ok. Checking is good practice ;-)
