Sverchok IFC
Following on my question in https://github.com/nortikin/sverchok/issues/3574
1. How is the IFC create shape supposed to work? I exported an ifc file with a wall and loaded it with sverchok, it recreates the geometry, but it doesn't have the classification (it is an ifcElement instead of ifcWall) and all the Qtos and Psets are empty.
2. Is it meant mainly to be used to generate ifc files directly or to aid with generating bim inside Blender?
3. Is there a way to add a text linked to an element?
4. Shall we have a separate git for ifc nodes or is the sverchok git the right place?
@Moult for the start these IFC nodes are good, but if I were you I wouldn't do that
IFC by Type (Type and Entity) is good if type be a selectable field, something like IFC elements window/menu in BlenderBIM
I saw that recently you finished the drop-down menu which maybe helps
The IFC nodes are purely a starting point for discussion about what we'd like / need in nodes. I haven't yet actually used it for any productive output.
@ReD_CoDE using dropdowns instead of text fields is a good idea! Would you like to help implement it? The code for nodes is quite small, so it should be straightforward.
changing the value of the "related element" in text "paper space"
I also tried something simpler:
any idea why it doesn't work?
@Moult as you know I'm not a programmer, but I'll help based on the ideas I had about IfcXtreme
And I think in BlenderBIM you've done the majority of steps are needed to develop IFC nodes
Please consider that IFC is not just available classes on spec, many companies need to develop their own experimental classes based on IFC rules
Nobody is born programmer you became a programmer by learning and programming. Many non programmer are programming. eg. An astronomer now spent la large part of his time programming analysis to find new star, planet, satellite, asteroid etc…
Also nowadays you learn programming basics in any university even in college / high school. Even without mastering any language / framework / environment it might help you to write more constructive feedback. Sverchok is visual programming.
No pressure, I just wanted to point it out as I've seen you repeating this several times.
@Cyril maybe in the long-term I spend my time to learn to program, but these days as a short-term scheme, I prefer to spend/invest my time in thinking and ideation
Believe me, developing tools is not just about programming, without enough time for R&D, you will develop average tools that many want them :))
Edit: I repeat this because Dion constantly encourages me to learn to program, and I repeat the aforementioned sentences :)
@Moult where are all Ifc Types? Are they in
blenderbim.bim.schema.IfcSchema().IfcElementType
? I looked at your code and changetype
field toEnumProperty
so it will be a dropdown. I don't know how to use Sverchok yet, so I hope it will work. Here is the PR: https://github.com/IfcOpenShell/IfcOpenShell/pull/1081@ReD_CoDE we are not born programmers. We are all thinkers, unless we were dead. Some of us realized our thoughts.
@htlcnn It's better everyone do the job that is expert in it
Programming is not in my list
I share ideas with you and others, and it's up to you to build them or not
In the end, I follow my own schemes and you follow your own schemes
I don't spend my time on less important things
@htlcnn It's a couple of months @aothms works on EXPRESS parser that was a little bit old and needed some improvements
IFC types (type and entity) are inside the IFC schema/spec
But you guys mainly work based on Ifc (step) file
Schema/specification and Ifc file format are two things
A huge kudos and thanks to @htlcnn for implementing the dropdown in the node! It only took editing 6 lines of code! https://github.com/IfcOpenShell/IfcOpenShell/commit/322f3773e491501c2e0dd45eafb6f61bea4d9494
This made me remember the story of the guy that fired the mechanic he had in the factory. All his machines were working properly for ages and for ages it seemed to him that his mechanic was doing nothing all day.
One day his main machine got broken and he asked his mechanic if he could fix it. The guy charged him twice the months of payment he had missed since he had been fired.
The factory owner got angry and went on to find a cheaper mechanic. He had a lot of work assembling and disassembling it but failed to fix it. The owner paid him his job and went on to find another.
This happened several times until he had spent the same money that his ex employee charged. He agreed to pay him his fees but only after the machine was fixed.
The mechanic fastened a screw and the machine got working again.
I guess variations of this story are being told everywhere, but I think it's a nice one.
Here is my take on the Sverchok version of IfcDumbWall, couple of things I cant't get to work:
