Blender BIM Saving TIME
Hello guys, I started using the BONSAI extension in Blender. Everything works great, but when I save an IFC file, the saving takes terribly long. It moves at about 3kb per second. When I have a model that's several MB, it takes several minutes.
Have you encountered something like this? Do you know where the problem might be and how to fix it?
Thank you in advance
My model is 3.9 MB, and takes maybe a second total to save. Something sounds abnormal. Have you tried some example models (like the AC20-FZK-Haus.ifc), and see if the speed is also slow? What are you writing the file too? Local storage? Dropbox? Network drive?
Either way, (your system is slow, or just your file is slow, to save) you should raise a bug. Paste the debug info available by clicking the button in the Debug panel in the Quality and Coordination tab.
I noticed it takes signifcantly longer when I save a file on a server, are you storing the file to a local disk or a remote location ?
