IFC LINKING FROM CIVIL -3D TO REVIT
Hi, I'm currently working on linking an IFC exported from Civil 3D into Revit, but I'm facing some alignment issues (but both civil-3D file and Revit file has same Co-ordinates and same georeferenced and other thing is when i import IFC 4 into it is not linking it says cant open the file but not in the IFC 2X3 but it miss aligned). The same IFC aligns Exactly in case of Revit 2026 Version.
Would really appreciate your guidance if you've dealt with similar workflows
Hmmmm. This forum is for open source software (or at least related to open source) hence the OS in OSArch. You appear to be using two expensive, closed-source, proprietary applications with no open source involved. I expect you pay lots of money for, and are entitled to support from the respective companies. Perhaps you could try making them earn their expensive licensing fees?
