Error in Creating IFC Space Using Blender + Bonsai
Hello everyone,
I created an IFC file using IfcOpenShell,
and I'm trying to generate IfcSpace using Blender + Bonsai.
It works well for the first space with a regular, boxy shape,
but in the second case — like in the video — the irregularly shaped space doesn't appear correctly.
What could be the issue?
  • @jhdf123 i think it is a bug, could you please open an issue in github? Also, could you try to use "create from cursor" and check if it works? Thanks, Massimo
    ChatGPT의 말:
    It was a problem caused by my incorrectly created object. Thank you.
    Massimo
