How to use Blender-Bonsai
Hello everyone,
I am working on generating IFC files from PCD files using IfcOpenShell.
Currently, when creating objects such as walls, I used IfcRectangleProfile with IfcExtrudedAreaSolid (z-up) to generate 3D modeling.
After that, I attempted to modify the object's dimensions through Blender-Bonsai.
Since the typical method (IFC Item Mode) did not allow modifications, I tried editing the wall object in IFC Edit Mode, where it is common to modify the profile's vertices.
I also adjusted the size by modifying the vertices, but I noticed that the object's profile changed from IfcRectangleProfile to IfcArbitraryClosedProfileDef.
Is there any way to modify the object's dimensions in Blender-Bonsai while keeping it as IfcRectangleProfile?
Thank you in advance.
It 'might' be related to this, not sure: https://github.com/IfcOpenShell/IfcOpenShell/issues/6481
