Project Library vs Libraries
Under Project Setup we have "Project Library" and also just "Libraries".
For example I have created one Doors.ifc file that has custom created doors in it.
In the actual project ifc file I have selected this file and then added a project library named DoorLibrary and inside which I have added doors using "Assign Library Declaration" (fancy name) and then Saved Library File. I have also copied this Doors.ifc file inside AppData/Roaming/bonsai/data/libraries folder so it can be easily accessed.
But what for is "Libraries" and inside it: Add Library, Enable Editing Library, Add Library Reference and so on?
