Depth and Width in Qto_SlabBaseQuantities
I think there is an error in the assignment of Depth and Width for slabs (IfcMaterialLayerSet) in the qto-function...
https://ifc43-docs.standards.buildingsmart.org/IFC/RELEASE/IFC4x3/HTML/lexical/Qto_SlabBaseQuantities.htm
  • edited February 13
    i could be wrong, but i think what determines length and width is based on the x and y direction the profile relative to the rotation of the origin--not whether an edge is longer or shorter--if that's what you were inferring.
    So if you want these to read inversely, i would tab into the slab and rotate the profile 90degrees.
    steverugi
  • I think, according to my interpretation of the definition in the ifc spec, the width should always be this value in case of an slab with IfcMaterialLayerSet:
  • I see what you're saying! Yes, having read the spec i would agree with the following...
    ping @Massimo thoughts?
    IFC Quantity What it REALLY is How humans say it
    Width Thickness slab thickness
    Length Plan dimension slab length
    Depth Plan dimension slab width
  • Does it change if you select Blender engine instead of ifcopenshell?
    My 2 1/2 cents as a human QS..
    for a slab (horizontal layer) length and width are the horizontal dimensions, depth the vertical one (thickness)
    but buildingSMART says differently:
    in case of a slab or horizontal element depth in my opinion should be the extruded dimension
    PS consulting Grok, ChatGPT, and Gemini they confirm my view= width and length are dimensions visible in plan view, depth in section view
    zoomersemhustejNigel
  • Huh, I think we all agree the spec is silly here. I assume its for "consistency" with walls.
    PR welcome to fix Ifc5d.
    KoAra
  • Just to clarify, I don't see anything wrong with Qto_*BaseQuantities for IfcSlab and IfcWall, they correctly measure their _extrusion_ and the other two dimensions.
    For IfcWall its thickness is expressed as "Width", given its LayerSetDirection AXIS2 (Y)
    while for IfcSlab thickness goes with "Depth", its LayerSetDirection AXIS3 (Z)
    Sure there might be cases where a particular slab geometry is created by extruding a X/Z profile along Y axis (concrete staircase/ramp, which have their own class), but in floors everybody measure it as WxLxH, Depth being the smallest of them, or just area (horizontal dimensions WxL, or calculated polyline) by height/thickness (H).
    If anything to fix I'd humbly suggest the way Qto_SlabBaseQuantities are described in the page.
    Interesting topic by the way, thanks
    KoAraatomkarinca
  • :) I associate depth with pouring concrete and gravity
    steverugi
    Just to add a central European pov:
    here the z dimension would be either thickness, or height. Depth is even weirder than width.
    Nigelzoomer
    no, its the same, but Length and Width are switched
    Massimo
  • RioRio
    edited February 14
    I agree - thickness seems to be a better term if changing the ifc spec in the future. In the meantime, I think it would be best to stick to the current IFC specification definition to maintain interoperability in projects.
    theoryshawMassimo
  • @Rio
    could you please point to a case where the current Qto values caused issues? thanks
  • For work, I check tender quantities against the corresponding IFC models. The models we review come from OpenBIM projects, where each project is planned by different companies using different software (Revit, Archicad, Allplan, etc.).
    I discovered the discrepancy when I summed up the wrong net volumes for slabs – in Austria, we group them, among other parameters, by slab thickness (e.g. my query sums up the netvolumes of all slabs with a max. width of 5,0 m instead of 0,25 m). So this use case of automated quantity takeoff relies on standardized quantity definitions to ensure consistent quantities, regardless of the authoring software used.
