How to extract the property sets from IFC file
Hi
I have two questions regarding the attached IFC file.
1) How to extract all the property sets from IFC file?
The code I tried is
import ifcopenshell.util
import ifcopenshell.util.element
ifc_file = ifcopenshell.open(input file)
products = ifc_file.by_type('IfcFlowSegment')[0]
line1= ifcopenshell.util.element.get_psets(products)
print (line1)
The output
{'12d Model': {'Geometry': {'id': 60, 'type': 'IfcComplexProperty', 'Name': 'Geometry', 'Description': '12d_attribute_group', 'UsageName': None, 'properties': {'Justification': 'Obvert', 'Start x': 51931.177, 'Start y': 158115.545, 'Start z': 3.403, 'End x': 51923.207, 'End y': 158110.611, 'End z': 3.656}}, 'PUP': {'id': 68, 'type': 'IfcComplexProperty', 'Name': 'PUP', 'Description': '12d_attribute_group', 'UsageName': None, 'properties': {'ID': 'SBCP-L181120-00011025', 'Owner': 'BCC', 'Description': 'PIPE', 'Creator': 'B+B', 'Creation Date': '20181126', 'Creation Source': 'SURVEY', 'AS 4588 Quality': 'B', 'Comment': 'nc', 'Material': 'STEEL'}}, 'Label': {'id': 78, 'type': 'IfcComplexProperty', 'Name': 'Label', 'Description': '12d_attribute_group', 'UsageName': None, 'properties': {'PipeSize': 'Ø100'}}}}
How can I Iterate so that all the property sets are extracted?
2) How can I get the properties in the above output into a dataframe?
The code you've written already extracts all the property sets. I guess your question is how to iterate through the dictionary. Try this (untested):
From this, hopefully you can work out how to get it into data frames.
I tried the above code
Below is the error message I got:
failed to load properties: 'list' object has no attribute 'is_a'
File "C:\Users\Shilpa\anaconda3\envs\myenv\lib\site-packages\ifcopenshell\util\element.py", line 4, in get_psets
if element.is_a("IfcTypeObject"):
AttributeError: 'list' object has no attribute 'is_a'
It worked when I gave the index value [0]
psets = ifcopenshell.util.element.get_psets(products)
How can I iterate through the file and extract all the property sets?
I could iterate using the for loop
Thanks for sharing the code.
Cheers, glad you got it resolved!
Dear Moult and Shilpa, I have tried the codes above on IfcWall and IfcSlab (using an IFC2x3 model). I only get an error message. Please help.
Below is my screen shot.
I used this IFC model
get_pset() expects a single element and got a list of walls. Try to get a sigle wall with something like ´get_psets(my_walls[0])´ or a loop.
I am grateful for the help
After reading through the https://wiki.osarch.org/index.php?title=IfcOpenShell_code_examples
I was able to at least use the sample code to extract the wall pset as dictionary.
1 These are the imports I am using
import ifcopenshell
from ifcopenshell.util.selector import Selector
from ifcopenshell import util
import ifcopenshell.util.pset
import pandas as pd
2 The IFC file I am using as attached
ifc = ifcopenshell.open('Duplex3.ifc')
selector = Selector()
3 The walls and slab using the by_type function
walls = ifc.by_type('IfcWall')
slabs = ifc.by_type('IfcSlab')
4 The iterations for the psets I did.
for wall in my_walls:
wall_details = wall.get_info()
for wall in walls:
pset_wall = ifcopenshell.util.element.get_psets(wall)
NOTE: I am trying to extract the quantities of Walls and Slabs and place them in a dataframe.
I want these to have their GUID.
I would also like to group all the Walls external walls based on their Cardinal points (south, north, etc)
once again thank you for your anticipated responses.
@Shilpa said:
@Shilpa please kindly assist me.
A bit outdated, but perhaps useful for someone.
What worked for me was (not sure how to format functions here properly)
This function can then be called with any ifcopenshell.entity_instance, e.g.
The dictionary can then be flattened and converted to a dataframe with something like
@ghesselink hi! you can format your code with markdown syntax:
I seem to not be able to edit my own post. I didn't realise you can use markdown here.
The answer with markdown:
