Can't import ifc geometries! :(
when I import the attached file in blenderbim the geometries do not appear! this happens with several files here! Viewers open normally!
This file
At my end it does.
If you can't see or select them, try adjusting focus length. It helps for me.
It comes through correctly for me. Try selecting an object in the outliner in the top left, then click on View -> Frame selected to zoom to the selected object.
got it! thank you guys!
