IfcBuildingElement class attributes
All building element have som direct attributes which do describe the object but are not in a pset but in the entity directly. A IfcDoor for example has
Name, Description, ObjectType, OverallHeight , OverallWidth, PredefinedType, OperationType, SINGLE_SWING_LEFT, UserDefinedOperationType
Is there a possiblility to get all these attributes without implementing the name of them directly? Something like we have with the comon psets definition.
We had this discussion recently with theoryshaw and Moult. I documented it on wiki : https://wiki.osarch.org/index.php?title=IfcOpenShell_code_examples#Exploring_IFC_schema
great :-)
I noticed that the example in the wiki doesn't include a check for whether the attribute is derived. Note that this can be important if you are doing bulk checks. Use the
element.derived()
function.What is the difference between a derived attribute and a not derived attribute.
Derived is a parent's class attribute
not in sense of coding but in sens of ifc. Which class attribute is derived and which not?
Does this mean a derived attribute is the same as a referenced attribute?
A described by Wikipedia:
An example may be IfcGeometricRepresentationSubContext, which if you read the express definition, has 4 derived attributes. It is important to check if you are automatically setting attribute values since it is not possible to set a value to a derived attribute.
Hello to all the contributors. All your responses give a super valueable information.
I would like to ask** if there is any util in ifcopenshell to get the inverse attributes of an entity**(python)as they are extremely useful to understand how the element is positionned in the schema and its relations. In the page
explicit and derived attributes are retrived but I miss a list of the inversed. Any idea?
I'm a newbie, but the following might help.
I've attached a BlenderBIM/IFC file to try it out.
Output...
Awesome that you added it to the wiki!
