I wonder if there is a way to filter/select the transparent parts of windows and curtain walls in BlenderBim?
You can edit the material and all should be changed, otherwise I think select by material might help?
@Max said: I wonder if there is a way to filter/select the transparent parts of windows and curtain walls in BlenderBim?
Do you have any example file showing what you want to do?
Added 'BlenderBIM' to the subject line
