IfcTester - Error on IDS with classification system
Hi Dion @Moult,
I'm really exited about IfcTester, discovering its possibilities and eager to implement this within my company. However, when I run my IDS with IfcTester I get this error:
File "C:\Users...\PycharmProjects......\ifc_validator.py", line 42, in
my_ids.validate(my_ifc)
File "C:\Users...\PycharmProjects....venv\lib\site-packages\ifctester\ids.py", line 118, in validate
specification.validate(ifc_file, filter_version=filter_version)
File "C:\Users...\PycharmProjects....venv\lib\site-packages\ifctester\ids.py", line 230, in validate
facet.failed_reasons.append(str(result))
TypeError: str returned non-string (type NoneType)
I created my IDS with the following code:
restriction = ids.Restriction(options={"enumeration": classifications}, base="string")
my_spec.requirements.append(ids.Classification(value=restriction, system="NL-SfB", minOccurs=1, maxOccurs="unbounded"))
my_ids.specifications.append(my_spec)
The IDS works on IFC's where a classification system "NL-SfB" is present, but crashes when it is not. Wouldn't IfcTester just return a failed check instead of a Traceback error? Or am I missing something?
EXAMPLE: when passing
BIM basis ILS - 3.6 Classificatiesystematiek
[PASS] (149/149) *Classificatiecode.
Applies to:
All {'enumeration': ['IFCACTUATOR', ... , 'IFCWINDOWSTANDARDCASE']} data
Requirements:
Shall have a NL-SfB reference of {'enumeration': ['11.10', ... , '90.83']}
Cheers,
Wout
@chachi_ws thanks! Is this the bugreport you've submitted here? https://github.com/IfcOpenShell/IfcOpenShell/issues/3202 If so, I think this is now fixed.
Thanks for the quick reply, much appreciated! And no I did not report the bug, but I'll keep in mind at reporting on github next time.
@Moult , tested your bugfix and it works like a charm, Thanks!
