Difference approaches using ifcopenshell
Hello everyone,
I just started getting familiar with ifcopenshell and during my research I was wondering about two different approaches that I found.
I want to convert Three.js geometry likes boxes to IFC using ifcopenshell and found two good examples that both use ifcopenshell but have completely different approaches.
One using ifcopenshell
And the other using ifcopenshell.api
Could you tell me what's the difference and which one would make more sense to use?
I personally like the way of using createIfcAxis2Placement3D to place objects but couldn't find most of the methods that were used in that example in the documentation.
Best,
Niklas
Definitely use the API where possible. The first link is from 2015 when the API didn't exist.
The shape_builder utility is also recommended if you want to construct custom solid geometry https://blenderbim.org/docs-python/autoapi/ifcopenshell/util/shape_builder/index.html whereas https://blenderbim.org/docs-python/autoapi/ifcopenshell/api/geometry/add_sverchok_representation/index.html is recommended if you're doing pure meshes.
You don't find functions like
createIfcAxis2Placement3Din the documentation because they are auto-generated. You can run createFoo where Foo is any valid IFC class such as from this list: https://standards.buildingsmart.org/IFC/RELEASE/IFC4/ADD2_TC1/HTML/link/inheritance-general-usage-all entities.htm - it wouldn't make sense to duplicate the entire buildingSMART docs. This is synonymous with https://blenderbim.org/docs-python/autoapi/ifcopenshell/file/index.html#ifcopenshell.file.file.create_entityThanks @Moult
The shape_builder utility looks great
Even though I have some hard time understanding how to use it properly to create IFCWall and IFCSlab since I apparently can't use the IfcExtrudedAreaSolid to create a wall representation.
How would I go for this or are there any examples to look at?
Here's an example: https://github.com/IfcOpenShell/IfcOpenShell/discussions/3260#discussioncomment-6108102
In short after you build your shape with the shape builder, turn it into a representation with
get_representation()then run thegeometry.assign_representationAPI.That worked perfectly! Thank you!
I'd have one last question regarding this one:
How is it possible using "pure meshes"?
I want to create a terrain in the IFC-file and therefor I have a terrain mesh represented by vertices and indices.
How can I use the
ifcopenshell.api.geometry.add_sverchok_representation()function you mentioned to create the IFC terrain similar to this one:https://cvillagrasa.github.io/IfcOpenHouse/generation.html#creating-the-terrain-as-a-nurbs-surface
This is the constructor of add_sverchok_representation:
So you can do something like:
