Clean Install including Sverchok
Hi
I am doing a Clean Install on a new Win11 computer of Blender, BlenderBIM Addon, Topologic, Homemaker and I want to also install Sverchok.
On my current computer everything is working except Sverchok, I get an error when I try to install it, so I didn't pursue a fix.
I am hoping someone will direct me to the current version of Sverchok and give me any hints about avoiding installation issues.
Thanks in advance
BlenderBIM rock and so does this community!
  • edited August 2023
    You mean IFC Sverchok or just Sverchok? What's the error traceback?
    Recently tried installing sverchok from their releases page and IFC Sverchok from the readme - didn't get any errors.
  • Thanks @Andrej730 I will follow your links for a successful outcome ?
  • I get the "404 page not found error" when trying to download IfcSverchok from there, has there been an update? Trying to install it for blender 4.1
    I guess something happened after moving the server. You can download the latest build from github page (need to download the entire repo and sverchok is in src/ifcsverchok folder) or download ifcsverchok folder directly e.g. using download-directory.github.io.
    There wasn't really new features for ifcsverchok, just api updates.
    jes_rShegs
  • edited April 2024
    Thanks! I was looking at how to download the folders instead of only the files ;) So just download it, zip it if that's not already done and install the normal way like BlenderBIM?
    Edit: it says ZIP packaged incorrectly. Anybody know what to do?
  • edited April 2024
    Oops, yes, it says ZIP packaged incorrectly; __init__.py should be in a directory, not at top-level, I guess just downloading the folder won't work. Then for now you can either unpack it to "ifcsverchok" folder in you blender addons directory (usually it's something like "%appdata%\Blender Foundation\Blender\4.1\scripts\addons") or change structure of zip archive - create ifcsverchok folder and move all files in archive to that folder and install it again.
    UPD: I've updated the IfcSverchok README on github page with the fresh url, new sverchok releases are also will be available now on github releases page.
    jes_rMaartenFrough
  • edited April 2024
    Amazing, this works perfectly! Thanks!
    For the others: if you download from the github release page you can install it like any other plug-in.
    MaartenFroughatomkarinca
