HOW TO ADD 2D GEOMETRY TO CUSTOM MADE WINDOW ON BlenderBIM v0.0.230902
Hello everyone. Using latest version of BlenderBIM, I was following IFCArchitect tutorial on how to make "ifc custom window" but I got stucked at where he added plan to the model. I started getting different outcome from his when Plan/annotation/Plan_View was added to ifc represention of the model. Instead of getting a planlike form I was getting elevation form. All other things I did after that were just going wrong. Please help!
Can you share any screenshots or IFC files?
It might be because the local Z is in the wrong direction.
video: https://www.dropbox.com/scl/fi/slat353zlkftt2hdqcce9/2023-09-24_11-49-35_Blender_blender.mp4?rlkey=td4d0602thh4btnl9lv5061px&dl=0
Gotten it! Thank you very much @theoryshaw. But if I may ask, how can I keep my local X,Y, and Z axis constant when rotating object.
@ramadankinwal the local axes move along with the object, so if you rotate the object, the local axes rotate too.
Thanks @Moult
You can rotate object in EDIT mode.
It works, thanks @Andrej730
