IFC Surface Style Missing
Hello, I’m using Blender BIM 230902 in blender 3.6, I got the problem that if I modified an element in edit mode the IFC style will lose when I save, when I reopen the file, it only contains the material, but the IFC style property is missing. I tried to reassign the material with the IFC style created but every time I save the process repeat, I have geometry with grey colors only.
The IFC original file is created from inventor with the help of a plugin called BIMDeX.
can you share the IFC file, or a parred down version of it? And point us to the object you're trying to change?
Sure, here are the example files.
This is not intuitive, but here's a few steps to correct...
https://www.dropbox.com/scl/fi/xnzzwq2q5z5o02abro1f9/2023-10-03_14-25-06_Blender_blender.mp4?rlkey=4key298bh5yj85jv51aekkqf7&dl=0
Thanks this help a lot! :D
