i create the slab and beam with the top parallel so that on the plan the beam lene were visible. how do you make sure the beam is not visible in the floor plan ?
Select the floor plan (camera in view or IfcAnnotation/FloorPlanName under Views Collection) as shown in .
After the selection look for and edit the EPset_Drawing on the Object Information tab and add “IfcBeam” to the “Exclude” parameter as shown in .
I hope this helps.
thank, this is very helpfull
