See if this works:
1) Find the annotation Global ID
2) Copy it
3) paste in the exclude line in the Camera Pset:
4) Print to SVG to check:
It should hide the level annotation
Thanks @ace! Yes that would work. Would be nice if there was a way to selectively turn off a particular level on all drawings, without having to do this for every section/elevation, for example.
It would be great if hiding individual objects could also just be linked to the render visibility in the outliner:
But I'm sure it's much more complicated to make it that simple
See if this works:
2) Copy it
Yeah, but the problem is, it's all just one object, so it turns off all the annotations.
