blenderBIM window list with global orientation
Hi everyone,
I´m using blenderbim quite often for energy calculations. In this process I currently use a combination of blenderbim - Sketchup and other methods.
One of my main tasks for my evaluation is to get correct window informations.
I use ifc2csv to get a complete window list with Heigth | Width etc. What I am not able to obtain is the global orientation of the window (to asses the solar energy gain).
I found Python code snippets in an earlier post
https://community.osarch.org/discussion/1026/ifcwindow-normal-according-to-world
Does someone know a way to combine ifc2csv with Python code or a similar approach?
Regards Hannes
NigelAce
  • I think the simple way to combine them would be to write a script to calculate the orientation and save it to some property set and then access it from ifc2csv.
    Acetheoryshawcarlopav
  • Agreed, using get_local_placement will give you vectors for X Y Z. X is east and Y is north: https://blenderbim.org/docs-python/ifcopenshell-python/code_examples.html#get-the-xyz-coordinates-of-a-element
    AcetheoryshawNigel
  • Thank you Andrej730 and Moult for your quick response.
    As I'm more a civil engineer than a programmer forgive my maybe silly questions
    I tried to execute the ifcopenshell commands in blenders Python console but could not get a result
    >>> import ifcopenshell.util.placement
    >>> window = model.by_type("IfcWindow")[0]
      File "<blender_console>", line 1, in <module>
    NameError: name 'model' is not defined
    >>> matrix = ifcopenshell.util.placement.get_local_placement(window.ObjectPlacement)
    AttributeError: 'Context' object has no attribute 'ObjectPlacement'
    >>> print(matrix[:,3][:3])
    Is there a possibility to execute the commands in the Python console of Blender?
    What I would like to find is
    • search the IFC Datastructure with BlenderBIM methods (IFC Search, point and click ...)
    • then execute the proposed script from inside blender on the search filter
    • write custom property set back to the search
    • execute IFC2CSV
    many thanks for your time
    Nigel
  • edited December 2023
    Hi again,
    I was able to get some way
    with the following code in the Blender Python console
    >>> for object in bpy.data.objects:
    ...     print (f"{object.name} has normal vector {object.matrix_world.col[1].to_3d()} and location {object.location}")
    I get a somewhat usable list
    IfcWindow/Fenster-011.017 has normal vector <Vector (1.0000, 0.0000, 0.0000)> and location <Vector (3508.8879, -494.1635, 3.8000)>
    IfcWindow/Fenster-011.018 has normal vector <Vector (1.0000, 0.0000, 0.0000)> and location <Vector (3508.8879, -489.1644, 3.8000)>
    IfcWindow/Fenster-011.019 has normal vector <Vector (1.0000, 0.0000, 0.0000)> and location <Vector (3508.8879, -489.1644, 3.8000)>
    IfcWindow/Fenster-011.020 has normal vector <Vector (1.0000, 0.0000, 0.0000)> and location <Vector (3508.8879, -494.1635, 3.8000)>
    IfcWindow/Fenster-011.021 has normal vector <Vector (-1.0000, 0.0000, 0.0000)> and location <Vector (3516.6328, -493.8635, 3.8000)>
    For me this can be a good start, but it is the complete list of objects in the file.
    What I now would like to achieve is to use a filtered and selected list from blenderbim
    select this list in the console
    >>> for selected_object in bpy.context.selected_objects:
    ...     print (f"{selected_object.name} has normal vector {selected_object.matrix_world.col[1].to_3d()} and location {selected_object.location}")
    and I get the filtered list!!!
    My next steps would be
    • add custom pset from Python console to selected_objects (any hints how to)
    • add normal vector to pset
    • ifc2csv
  • Happy New Year,
    I´ve been busy before the holiday season and therefore was not able to nail down some points.
    I tried to get the GUID with the python script
    import blenderbim.tool as tool
    print (f"{selected_object.name} ; has normal vector ; {selected_object.matrix_world.col[1].to_3d()} ; and location ; {selected_object.location} ; height ; {selected_object.BIMWindowProperties.overall_height} ; width ; {selected_object.BIMWindowProperties.overall_width} ; type; {selected_object.BIMWindowProperties.window_type} ; GlobalId ; {tool.Ifc.get_entity(bpy.context.selected_objects[0]).GlobalId}")
    But I´m getting a list with the Windows, orientations, positions but only the first overall_heigth, overall width, window_type and GlobalId?
    IfcWindow/Element ohne Kämpfer:FET 1-tlg - ML 1100 x 2570 - FB ; has normal vector ; <Vector (-0.0000, -1.0000, 0.0000)> ; and location ; <Vector (19.7464, 1.1184, -0.2000)> ; height ; 0.8999999761581421 ; width ; 0.6000000238418579 ; type; SINGLE_PANEL ; GlobalId ; 04BQj6$jz1Oh70$fH7F2rh
    IfcWindow/Element ohne Kämpfer:FET 2-tlg - ML 2100 x 2570 - FB ; has normal vector ; <Vector (-0.0000, -1.0000, 0.0000)> ; and location ; <Vector (12.3864, 1.1184, -0.2000)> ; height ; 0.8999999761581421 ; width ; 0.6000000238418579 ; type; SINGLE_PANEL ; GlobalId ; 04BQj6$jz1Oh70$fH7F2rh
    IfcWindow/Element ohne Kämpfer:FET 2-tlg - ML 2100 x 2570  ; has normal vector ; <Vector (-0.0000, -1.0000, 0.0000)> ; and location ; <Vector (9.5864, 1.1184, -0.2000)> ; height ; 0.8999999761581421 ; width ; 0.6000000238418579 ; type; SINGLE_PANEL ; GlobalId ; 04BQj6$jz1Oh70$fH7F2rh
    IfcWindow/Element ohne Kämpfer:FET 2-tlg - ML 2100 x 2570 .001 ; has normal vector ; <Vector (-0.0000, -1.0000, 0.0000)> ; and location ; <Vector (6.5864, 1.1184, -0.2000)> ; height ; 0.8999999761581421 ; width ; 0.6000000238418579 ; type; SINGLE_PANEL ; GlobalId ; 04BQj6$jz1Oh70$fH7F2rh
    Somehow I missed something. Can someone guide me to my error?
    Hannes
  • ArvArv
    edited January 2024
    Try this as tool.Ifc.get_entity(bpy.context.selected_object).GlobalId ie without indexing as selected_objects[0]
    Gorgious
