BlenderBIM : IfcMaterials on parametric IfcWindows
Hi,
I've just tried parametric IfcWindows, it's great!
How can I assign materials?
In Tessellations, I do it in Edit mode (btw it's great that we can even give transparency to the glazing, thanks).
Cyril
  • +1 Submitted a feature request over on github.
    https://github.com/IfcOpenShell/IfcOpenShell/issues/3295
  • edited February 2024
    Hi,
    I'm playing with this feature request, trying to hack an ifc created in BlenderBIM. I add these few lines:
    #641=IFCRELASSOCIATESMATERIAL('057L7ffhX7qwJ_QeoTevZa',$,$,$,(#375),#642);
    #642=IFCMATERIALCONSTITUENTSET($,$,(#643,#644,#645));
    #643=IFCMATERIALCONSTITUENT('Lining',$,#66,$,$);
    #644=IFCMATERIALCONSTITUENT('Framing',$,#97,$,$);
    #645=IFCMATERIALCONSTITUENT('Glazing',$,#97,$,$);
    But the entire parametric window always takes the value of Lining, regardless of the material assigned to Framing and Glazing:
    I've taken these names here : https://standards.buildingsmart.org/IFC/RELEASE/IFC4_3/HTML/lexical/IfcWindowType.htm#6.1.3.45.3-Attributes
    The following keywords for IfcMaterialConstituentSet.MaterialConstituents[n].Name shall be used:
    'Lining' - to indicate that the material constituent applies to to the window lining
    'Framing' - to indicate that the material constituent applies to to the window panels, if not provided, the 'Lining' material information applied to panels as well
    'Glazing' - to indicate that the material constituent applies to to the glazing part
    Am I missing something, or does this require development in IfcOpenShell?
    bdamaysteverugi
