AttributeError: "str" object has no attribute "id"
Hi!
I'm new IFC openshell and coding in general. Does anyone know why i get this error from my code.
Code
import ifcopenshell
import ifcopenshell.util.element as Element
file = ifcopenshell.open("\test.ifc")
walls = file.by_type("IfcWall")[0]
object_data = {}
for wall in walls:
object_id = wall.id()
object_data[object_id] = {
"ExpressID": wall.id(),
"GlobalId": wall.GlobalId,
"Class" : wall.is_a(),
"PredefinedType": Element.get_predefined_type(wall),
"Name": wall.Name,
"Level": Element.get_container(wall).Name
if Element.get_container(wall)
else "",
"ObjectType": Element.get_type(wall).Name
if Element.get_type(wall)
else "",
"QuantitySets": Element.get_psets(wall, qtos_only=True),
"PropertySets": Element.get_psets(wall, psets_only=True)
import pprint
pp =pprint.PrettyPrinter()
pp.pprint(object_data)
Errorcode:
line 12, in
AttributeError: 'str' object has no attribute 'id'
newbie too...
maybe
file.id(wall)@Bobob86 well, the line
walls = file.by_type("IfcWall")[0]gives only the first IfcWall in the file (look at the 0) ...
You need to get all the walls so delete the [0] and it should work ...
Yes, iterating over
file.by_type("IfcWall")[0]iterates over attributes of a first wall found instead of iterating over all IfcWalls in the project.
