Hello ! The temporary section cutaway feature adds a node group to the material of the object that is cut out, could you verify that the stairs and the walls share the same material ?
If you don't want them to share the same material, select the stairs, go into the shader editor, and add the "Section Override" node group just before the material output node's surface input :
@Guileoni if you're still struggling with installing the latest dev versions jump in the OSArch live chat and we can have a screensharing session when you're online :)
@Moult said: @Guileoni if you're still struggling with installing the latest dev versions jump in the OSArch live chat and we can have a screensharing session when you're online :)
I havent tried anymore.. what do i have to do?
just say hey I need help?
Thanks, I'll try it
@Gorgious
is it the same problem that I am having here?
@Guileoni this should be fixed in the latest dev builds, what version are you using ?
Blender 4.0
I think he meant BB version.
Here's the latest releases of BB: https://github.com/IfcOpenShell/IfcOpenShell/releases
There's actually been some new developments with 'section cutaways'.
video: https://www.dropbox.com/scl/fi/65kcmom6qs74dg908xehp/2024-03-05_16-06-34_CarnacKeyShowViewCarnac.mp4?rlkey=puhd9xh9z9gmbdf9yhl9rivvg&dl=0
From Github Releases I've just tried the 240306 and 240305 versions and there is a bug i couldnt install them.
What's your OS?
This might help: https://blenderbim.org/docs/devs/installation.html#unstable-installation
@Guileoni go here...
and download the file that ends in
-py310-win.zip
Thank you
It worked!
