BBIM - Possible to save view settings as snapping and gizmo in Ifc?
edited March 2024 in General
Hi,
Quick question: Is it possible to save the view settings of e.g. snapping and the move gizmo in Ifc?
Its currently only saved in the .blend file, but maybe there is a way to quickly/automatically load them from previous session? It's getting a bit annoying to do every day every time I have to reopen, especially if working in multiple files.
Thanks!
JanF
  • I don't think you can save it to the ifc file currently (after all, it should be platform agnostic) but you can use the Blednder way - change the default file:
    (create an empty file with the default settings, change it to your prefered ones and update the defaults. Be careful, there's no way to undo this.)
    jes_rAce
  • Awesome, this works perfectly! These changes are small, so I won't worry about undoing.
  • Well you can store them in a custom Pset on your IfcProject object I guess and retrieve them later by parsing your Pset. I don't know if it's a correct way to do it though
    Bedson
