BBIM - generate space quantities with spatial tool
Hi,
When I generate a space, for example via the spatial tool and then automatically generate spaces from walls (very handy!), I have to select the 'wall tool' and then press 'generate all quantities' or Shift+Q for the quantities to be generated.
The shortcut doesn't work directly from the spatial tool either.
Wouldn't it be better to be able to do this here too?
Or maybe it's better to add a button here to quickly and 'manually' generate all quantities, instead of only 1 row at a time:
This way this would be a solution for every object instead of just spaces.
Just like you can regenerate everything by clicking this button if all quantities are already generated once:
Or, is it possible to automatically generate them when generating the space?
Just some ideas ;)
@jes_r yeah i think it would be helpful too... in particular, i think that adding the shortcut shift+q also in the tool spatial menu is the best (and simpler) solution ...
Could you file an issue in GitHub about it? Thanks :-)
@Massimo done! This is the link, for if you wanted to +1 ;)
