How to extract type relationships (parent?)
Hello. I am trying to extract the names and other IfcSpace information from an IFC file. I see that there is an IfcSpaceType, and was wondering if there is a way to extract this information in the context of the IfcSpace using the CSV exporter (i.e. columns with space name, long name, what is referred to in the screenshot as a Type Product).
Use the magic
type
keyword. Attributes and properties are appended with a.
dot. E.g.type.Name
,type.GlobalId
,type.Pset_foo.Bar
. Hope it helps :)By the way, if you right click on the type product highlighted in red in your screenshot and click "Jump to target" that's a quick way to select the type and see its properties.
Excellent! Thank you.
