blenderBIM installation issue
Good morning everyone,
I have an issue with the blenderBIM installation process. When I check the box to enable the Add-on I get the following error that I attach in the images below. Can someone help me? Thank you in advance!
I already checked for a similar issue in this forum but no methods worked.
PS: I have the LTR of Blender (3.6.10), the 3.11.9 Python version, and the latest version of blenderBIM Add-on.
https://community.osarch.org/discussion/comment/20001/#Comment_20001 ?
Thank you so much for the tip!
It happened to me today.
Blender 4.1 and blenderbim-240416-py310-linux
maybe...
https://docs.blenderbim.org/devs/installation.html#unstable-installation
For Blender 4.1 you need a 3.11 Python version, I fixed the problem following the unstable version instruction.
It worked. Thanks!
Hi, I have installed Blender 4.1.1 and downloaded the latest BlenderBIM build 'blenderbim-240503-py311-win.zip' I get the error message below. I have checked Python 3.11 is installed and checked 'Successfully installed numpy-1.26.4'
I'm very much a novice so any help will be appreciated and best delivered as a '**Dummies Guide to ... **'
@Nigel see FAQ number 4? https://docs.blenderbim.org/users/installation.html#faq
Good evening @Moult yes that fixed it, thank you. As I was looking at the Addons I remembered talk on the forum about BlenderGIS being a problem in the past, I don't know if that is still the case.
