[IfcOpenShell] Removing IFC data
edited June 2022 in General
Hi. Just wondering if it was possible to remove p_sets or other metadata using ifcopenshell and/or blenderBIM
  • You mean an ifcpatch to remove a list of psets ?
    Else in Blender + BIM addon of course you can remove any attribute/property/pset.
  • Hi everyone. I'm coming back to this item. The link above broke, but I'm assuming the updated one is: https://github.com/IfcOpenShell/IfcOpenShell/blob/v0.6.0/src/ifcopenshell-python/ifcopenshell/api/pset/remove_pset.py
    I've been able to get to the python console, but wondering if you could provide an example. My use case would be to remove all p_sets from an ifc, i.e. retain all geometry and type name, but no more.
  • @edwinguerra purging is not the same as "unassign a pset from a product", which is more an authoring usecase that I suggested above. For purging, here's some untested code which should be more efficient.
    import ifcopenshell
    f = ifcopenshell.open('model.ifc')
    for rel in f.by_type('IfcRelDefinesByProperties'):
        ifcopenshell.util.element.remove_deep(f, rel.RelatingPropertyDefinition)
        f.remove(rel)
    But may I ask why you are doing this? I have had similar requests in the past, usually because companies are afraid of their "IP" being lost or wanting to cripple BIM data for a recipient that they don't have a good relationship with. If so, I highly recommend you think twice about what you're doing, since the whole point of OSArch is to work together more.
  • Thanks Dion. Yes, it is along the lines of limiting liability when sharing to external parties, like a contractor, when not previously agreed upon or paid for. There are model release forms and all, but still there seems to be interest to prevent any further unintended use. A workflow exists currently which is to export to fbx, but I think IFC would be preferable. I agree, that the best would be to make the whole model and information available, yet there is still the belief that the contractor/subcontractor will get an advantage by using the model in its complete form. And then there are the modeling shortcuts that people take, so things may look good in 2D, but not in the actual model. Would be curious to know your thoughts on this. It would be great if in the future model was released alongside drawings. Preventing the manual take-off of items by all bidding parties alone would improve the karma of the industry.
  • My recommendation, without knowing your full situation, is to simply give them as much data as possible using open digital formats. At this moment, drawings are treated as the legal source of truth so if they misinterpret your model data (e.g. when modeling shortcuts are used), that is on them. Money being spent to recreate withheld data is a wasted opportunity for our built environment, especially when a lot of that money is in the public sector, or could otherwise be used to invest in innovation, sustainability, and other initiatives which, much like "open source / transparency", often get cut first from a project as a low priority item.
    We are already trending towards models being used as legal submissions and I know of a few projects where this is the case. We're already struggling to get rudimentary correct data in our models, let alone with people purposely sabotaging them.
    Coen
  • edited October 2021
    import ifcopenshell
        f.remove(rel)
    unfortunately the code snipped returns the following error:
    Warning:AttributeError : 'file' object has no attribute 'batch' [' File "", line 119, in \n', ' File "C:\Users\xxxxx\AppData\Local\python-3.8.3-embed-amd64\Lib\site-packages\ifcopenshell\util\element.py", line 126, in remove_deep\n ifc_file.batch()\n', ' File "C:\Users\xxxxx\AppData\Local\python-3.8.3-embed-amd64\Lib\site-packages\ifcopenshell\file.py", line 95, in getattr\n return getattr(self.wrapped_data, attr)\n', ' File "C:\Users\xxxxx\AppData\Local\python-3.8.3-embed-amd64\Lib\site-packages\ifcopenshell\ifcopenshell_wrapper.py", line 1419, in \n getattr = lambda self, name: _swig_getattr(self, file, name)\n', ' File "C:\Users\xxxxx\AppData\Local\python-3.8.3-embed-amd64\Lib\site-packages\ifcopenshell\ifcopenshell_wrapper.py", line 80, in _swig_getattr\n raise AttributeError("\'%s\' object has no attribute \'%s\'" % (class_type.name, name))\n']
    @Moult to your question why to do this:
    quite frequently i am receiving ifc data containing corrupt psets - meaning missing properties, ... or containing unagreed psets. in order to clean those files for further work i try to remove those unwanted data.
    peter
  • @PeterKop you are getting that error because you are using an outdated version of IfcOpenShell. You can download the latest from here: https://github.com/IfcOpenBot/IfcOpenShell/commit/61e510e45c00f303086a618a6dfd81e1d016d0c3
  • @Moult it was not an outdated version but a syntax error in my code. unfortunately;-)
    Moult
  • edited June 2022
    Is there really not a counterpart to
    ifcopenshell.api.run("pset.edit_pset", ifcfile, pset=the_pset, properties=the_property)
    for removing a property from a pset and from a ifcfile?
    I would like to delete some properties depending on the property value.
  • How to get rid of an entire IFC file in BlenderBIM using python?
    I used this, but it does not work
    bpy.ops.bim.unload_project(filepath=file_ifc)
    Console says it does not recognise the filepath, while it recognises filepath when using load_project :
    bpy.ops.bim.load_project(filepath=file_ifc)
  • There is an IfcStore.purge() method that wipes the current IFC model in memory.
    In the Homemaker-addon to refresh the scene, I just delete all the blender collections, then I call import_ifc.IfcImporter().execute() without giving it a filename and it will regenerate the blender model from whatever is in IfcStore.
    This is all a bit if a hack, there ought to be some nice utility methods in blenderbim that do the same things.
  • @brunopostle
    I did not know about IfcStore.purge().
    I now did it like this:
    project = ifc_file.by_type('IfcProject')
    for i in project:
        collection_name = 'IfcProject/' + i.Name
    collection = bpy.data.collections.get(str(collection_name))
    for obj in collection.objects:
        bpy.data.objects.remove(obj, do_unlink=True)
    bpy.data.collections.remove(collection)
    Are there maybe any things I'm not aware off? This seems to work
  • I have a problem where the undo history gets slightly messed-up doing this sort of thing (see pull request #2200), but otherwise it works
  • I got NameError: name 'ifc_file' is not defined, guess I missed to import something.
  • @Max ifc_file is probably a reference to an IfcOpenShell model. You can retrieve the model from blenderbim like so:
    ifc_file = IfcStore.file
    Max
    @Max
    Or like this
    import ifcopenshell
    ifc_file = ifcopenshell.open("[c:\path\to\your\ifcfile"])
    Max
  • I made my above post into little function which you could place at the end of your python script so it loads the changed model in BlenderBIM, it now also works when no IFC is loaded yet in BlenderBIM.
    def load_ifc_automatically():
        if (bool(ifc_file)) == True:
            if project is not None:
                for i in project:
                if collection is not None:
    No idea if this is good practice or not, but it seems to work.
    theoryshaw
  • A call to bpy.ops.outliner.orphans_purge(do_local_ids=True, do_linked_ids=True, do_recursive=True) right before the last line of the function will also purge the data from the blend file.
    brunopostleCoenvpajic
    import ifcopenshell
        f.remove(rel)
    Sorry for bringing back the old threads.
    The issue I have now is the duplicated custom Psets in the model, like in the log below. Solibri ITOs export to XLSX produces comma-separated values and the QTO is unacceptable due to large amount of manual rework needed (30k+ rows). There is no option to alter the initial models, so I need to deal with the issue on the IFC side. I can merge the Psets with different property sets, but I also need to remove the duplicated values.
    So, if I understand correctly, I should call remove_deep() for every definition and later remove empty the Pset with remove() ?
    I'm quite new to the IfcOpenShell, so sorry for the lame questions.
    >Processing 1TpcJF6WvFCukWLzRnclna: Pressed steel elbow:DN15-50:1976023
    >        'Parametrai'
    >        [By Property] : Storis '0.0 mm'
    >        [By Property] : Pavadinimas 'Pressed steel elbow'
    >        [By Property] : Tipas 'DN15-50'
    >        [By Property] : Klasifikatoriaus pavadinimas 'Techninė specifikacija'
    >        [By Property] : Kodas 'TS-1.2'
    >        [By Property] : Diametras '32.0 mm'
    >        [By Property] : Tūris '6.563161286979992e-05 m³'
    >        [By Property] : Medžiagiškumas 'Nerūdijantis plienas'
    >        'Parametrai'
    >            Duplicate Pset 'Parametrai' for GlobalId 1TpcJF6WvFCukWLzRnclna
    >            Duplicate property 'Storis=0.0' for 'Storis=0.0'
    >            Duplicate property 'Pavadinimas=Pressed steel elbow' for 'Pavadinimas=Pressed steel elbow'
    >            Duplicate property 'Tipas=DN15-50' for 'Tipas=DN15-50'
    >            Duplicate property 'Klasifikatoriaus pavadinimas=Techninė specifikacija' for 'Klasifikatoriaus pavadinimas=Techninė specifikacija'
    >            Duplicate property 'Kodas=TS-1.2' for 'Kodas=TS-1.2'
    >            Duplicate property 'Diametras=32.0' for 'Diametras=32.0'
    >            Duplicate property 'Tūris=6.563161286979992e-05' for 'Tūris=6.563161286979992e-05'
    >            Duplicate property 'Medžiagiškumas=Nerūdijantis plienas' for 'Medžiagiškumas=Nerūdijantis plienas'
    >        'Parametrai'
    >        [By Property] : Diametras1 '32-32'
  • If you're dealing with duplicate psets, you'll probably want to write different code. First, you should verify that it is truly a duplicate and doesn't contain different values. Also instead of remove_deep, I'd recommend using the API pset.remove_pset or pset.edit_pset (if you only need to purge or consolidate properties). It's a bit hard to say without seeing your exact IFC data.
  • The custom Psets have duplicating names and sometimes they present different properties, both by quantity and by value. My idea is to create a proper Pset (according to OIR), trim the same values, leaving just the unique ones. Any data clash could be resolved by adding a numeric index to the property name. This way I will preserve and store the proper data in the model.
    The code will be verified on a set of models in the debug mode prior to the production use, this is a must :)
  • I think a safer approach is to loop through all IfcObjectDefinition, IfcTypeProducts, IfcMaterial definition, and IfcProfileDefs.
    For each one, get their psets using the ifcopenshell.util.element.get_psets with verbose enabled, and create an entirely new pset/qto, then remove all existing psets/qtos.
    The get_psets utility already combines duplicate pset names together into a single dictionary. I've just committed a fix that makes it do it for types and materials and profiles too.
    Arv
