Bulk method for assigning IFC Class to native Blender mesh?
This is not a particularly pretty use case.
I have a blend file with ~2000 mesh objects, and I'd like to assign them all to a bog-standard IfcBuildingElementProxy class so I can do various IFC-related stuff to them.
Currently I simply select all the mesh, go to the Object tab and press 'Assign IFC Class':
For 2000 objects this freezes, although I think it is slowly working it's way through them.
I know that this operation isn't particularly simple what with having to create all the IFC-based information in the background for each object - but is there anything that I could do differently to make it better?
(I realise that not doing it in the first place is probably the best option...) thanks
It would also be great if the script could get a value from each mesh (from a standard Blender custom property. For example IFCSaveAs with a value of IfcPipeFitting) and then use this value to save the file as an IFC with each mesh having an IFC classification based on it's IFCSaveAs value....
If you're happy to write a script, it may be faster. If you know the structure of your meshes / know where styles are and aren't applied, that would speed it up too.
I've written a loop script using bpy.ops.bim.assign_class on each mesh. I don't know if it has anything to do with the speed of the operation, but for each object, I'm getting this prompt:
Failed to create a cache: H5Fopen failed.Writing the loop gives me an indication of progress, which is about 7 minutes per 1000 objects, not too horrible really.
Well I managed to fix the cache issue - for whatever reason I didn't have a 'cache' folder in the following path:
%USERPROFILE%\AppData\Roaming\Blender Foundation\Blender\4.2\extensions\.local\lib\python3.11\site-packages\bonsai\bim\data
I just made the folder and the Fail error disappears. Might be a bug, should probably file a report, but it's Friday :)
This cache folder shouldn't really be a subfolder of the static data folder. Ideally it would be outside site_packages altogether, as site_packages ought to be read-only, or the cache location should at least made configurable.
ie. On this Linux system I would want this cache in
$HOME/.cache/bonsai
