Is there a way to make these arrows bigger and get more space between the text? Have to zoom in very far now to see any distinction between them.
Not sure if this setting could help:- Edit Prefrences Add On Bonsia, scroll down
Thanks! But it doesn't influence the size.
Here is a nice sample from the service that IFC geospatial service from mister @brewsky Great resource getting models aligned to NL maps! https://bim-tools.github.io/perceel2ifc/
@Moult maybe you some ideas how to get UI somehow a bit better readable in a view? Geodata tends to be on a big larger scale than your avarage window of interior ;-) Regards Hans
Can you please report a bug for this? It's something we should support, similar to how the solar visualisation size can be customised.
I haven't tried yet, but it looks like @bruno_perdigao might have touched this a little: https://github.com/IfcOpenShell/IfcOpenShell/commit/0267e2b5e0e6555abcc0f58add1347e2ae311df4
Yes, I forgot to mention. I'll adapt to keep the same UI from the solar analysis.
@Moult Is there a georeferenced sample file that I can use? The solar analysis panel is not working for me.
Here is one.
Edit
Prefrences
Add On
Bonsia, scroll down
Regards Hans
Here is one.
